Parametric_Ozzy
hi enrico,Hi, patrick.
What you say is correct. It is undeniable that there are fields in which it shows merits compared to all midranges. if you have to make proe molds is the best tool among the cads mentioned in this thread, if you have to reverse inv. or swx are already cut, if you have to create complex fusions between 3 the only and proe.
If you have to do carpentry I do not know, I find proe less productive of swx, not only by personal experience, but also by comparing me with other colleagues I have not yet seen any productive as we with swx+r2w at equal documentation provided to the customer.
for this, to make the best choice, the greatest possible culture of all tools is necessary.
they must weigh foreplay and defects and see what fits best in their reality.
We've already talked about it in person, among other things you know that I'm drawing you first of all as a person and also for your way of working but unfortunately as I told you you you've been "feeled" too early in the discovery of pro/e, especially for your field of use, you've been using swx for more than 10 years you know it by heart, you know all the workarounds of the case, for me is the same thing in pro/e you know it.
but with this I absolutely do not want to say that you have wrong, I understand perfectly your reasons and sincerely support them also, I think I would do just as if I were in your situation, "losing" time to learn more thoroughly pro/e and all its facets takes time, sacrifice and aim is also costs and today with customers who beat the door every minute it is difficult to cut out this space and you go rightly with the tool.
I am firmly convinced that even your colleagues speak so purely for a lack of knowledge of the system or because simple people want to work with a method used for many years and working but that maybe for another system is not good, or it requires another way.
Unfortunately I cannot post documents and case studies made by customers who are colossi in these fields having signed clauses of non-disclosure, but speed and quality of documentation are guaranteed, clearly after a little time of asismlation of the instrument, this requires working daily for sure more than a full-time year to make a truly objective comparison.
to tell you all I have not recommended to a customer the sale of efx, recommending another way much more performing using tools based on a licensed base not known but that fall to brush for this kind of activity, so basically against my licensing interests, the result however was a customer satisfaction to double, one because it has spent less and second because it manages to do things practically at the same speed that using an advanced module is not said.
To conclude, I think there's too much but too many people talking just to hear, actually when you have the instrument in your hand you pity him to do what you always want, but you have to know it thoroughly! ! !
greetings patrick
