issue with serial number.
  • Thread starter Thread starter HOOPS
HOOPS
Hello everyone, I previously installed a version of inventor with an incorrect serial number, now even if I uninstalled it and reinstalled by changing the number (inserting the correct number) when I do the activation I remain in memory the serial number inserted the first time.
How can I do that? ?
in xp "c:\documents and settings\all users\dati applications\autodesk\software licenses\" this is the folder where the .dat license files of the installed autodesk products are stored, if you have more than one I recommend you to move them all, start inventor remake the activation procedure, recheck in this folder the name of the generated file and put back in place the others you have moved without the same name.
view has another path, but now I don't remember, I think you have to enter the roaming folder of the user folder, but I don't remember exactly.
I deleted all folder in c: / programdata / licensed software
now I have to reinstall the whole thing??
I didn't find any other files licensed
(use s.o. view prof.)
But I'm not sure.
from the drop-down menu < > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > on adsk inv --> product info --> num. prod series. --> updating is the possibility of changing the serial (with a note of attention )
What happens then, I don't trust to prove it...
Bye.
Now I tried to reinstall everything and then we see what it tells me.....
in the meantime thank you all for the help
nothing to do always takes the serila 123 12345678 that I had installed wrongly at first as a trial version (now that I finished the 30 days trial) that I can do? ?
I'm not getting into the program.
help:frown:
help:frown:
try to untie and then clean the registry (often the info in the windows register are not erased during the disintallation).
I don't know anything about inventor but often programs write information in:
hkey_local_machine\software\autodesk\inventor
or something like that.
Maybe with one of those tools that clean the registry (ccleaner) you can fix.
nothing to do always appears to me 123-12345678 cursed version 30g
Now I have to reform everything...:frown:
