ceschi1959
I had two problems with space pilot:
an egregiamente solved by axa that I enlighten you briefly.
in the main machine I installed nx4 and the space pilot, then nx5 and nx6 (work with all three) and I never had problems. in the laptop I installed nx5, the space pilot, nx6 and I had no problems, until I had to install nx4 for a customer. at the start of nx4 I appeared an error message of the type 'impossible to find the entry point of the library dynamic libnxopencpp.dll'. axa suggested that I correctly set the system variable ugii_3dconnexion_library when starting nx4 as it went to look for these bookstores in the wrong directory.
but now I have the same problem on all cars and on all versions as I bought a space pilot pro that works with different drivers, I uninstalled the old drivers and installed the new ones but the dll 3dxnx.dll was that of the previous device.
Can you help me?
Thank you all in advance.
:smile:
Can you help me?
:smile:
