issues con space pilot
  • Thread starter Thread starter ceschi1959
ceschi1959
I had two problems with space pilot:
an egregiamente solved by axa that I enlighten you briefly.
in the main machine I installed nx4 and the space pilot, then nx5 and nx6 (work with all three) and I never had problems. in the laptop I installed nx5, the space pilot, nx6 and I had no problems, until I had to install nx4 for a customer. at the start of nx4 I appeared an error message of the type 'impossible to find the entry point of the library dynamic libnxopencpp.dll'. axa suggested that I correctly set the system variable ugii_3dconnexion_library when starting nx4 as it went to look for these bookstores in the wrong directory.
but now I have the same problem on all cars and on all versions as I bought a space pilot pro that works with different drivers, I uninstalled the old drivers and installed the new ones but the dll 3dxnx.dll was that of the previous device.
Can you help me?
Thank you all in advance.
:smile:
..I can't help you, but I also found that type of problem...I installed nx6 on my pc that already had the nx4 version and from that moment with nx6 the space pilot pro worked correctly (I appeared the 3dxnx bar on the menu and let me customise the various buttons associated with the functions present in nx ), while in environment nx4 space pilot was no longer working (the bar present then I uninstalled the drivers (by the way newer) and now I have this situation: in the nx4 environment it works all correctly and I see the 3dxnx bar of the menus, while in nx6 the space pilot pro has kept the same customizations made in nx4, but it does not show me the 3dxnx bar anywhere, so I can no longer customize anything if I wanted. I still have to try to look inside this problem (in the past I had solved some problems going to see the forum on the 3dconnection site) to see if you can do something or not, but it is another testimony that shows that these drivers have problems when on the same pc there are different versions of nx (in my case nx4 along with nx6 )...
guys, I worked a lot myself with several versions of nx installed, usually 4 and 6 that among other things I still have on a 32-bit configuration.
Unfortunately I have never had any problems with any aversion.
I believe that the problem is not attributable to spacemouse but to the environmental variables of nx .
In fact, the problems of having many versions on the same machine are not limited only to that.
to avoid problems I had created bachfiles to start each version with its configurations.
if you can serve place an example for nx4 (file nx4ita.bat )
set ugii_base_dir=c:\ugs\nx 4.0\(PHP 4 = 4.1.0)
set ugi _ license _ file = 27000 @ vostroserver
set ugi _ root _ dir =% ugi _ base _ dir% ugi\
set ugi _ 3dconnexion _ library =% ugi _ base _ dir% ugalliance\ vendor\ startup\ 3dxnx. dll
set ugi _ flex _ bundle = nx13200n
"% ugi _ root _ dir% ugraf.exe"
e questo è per nx6
set ugii_base_dir=c:\ugs\nx 6.0\set ugii_lang=italian
set ugs_license_server=28000@vostroserver
set ugii_root_dir=%ugi_base_dir%ugi\
set ugii_3dconnexion_library=%ugi_base_dir%ugalliance\vendor\startup\3dxnx.dll
set ugii_license_bundle=nx13200n
"%ugi_root_dir%ugraf.exe"
as you can see the only variant is the ugii_base_dir environment variable
but among other things it serves to vary the dll of the spacemouse depending on which version we have uploaded.
I didn't check, but I don't think the 2 dlls have anything else in common besides the name.
do know if you have solved :rolleyes:
