keyboard commands in catia v5
  • Thread starter Thread starter Steel59
hi teens take advantage of this topic to ask if there is a function to repeat the command or to keep it always pressed... since on you tube or seen videos where there is more than one user who succeeds in this small enterprise.
another questionnaire but the command ''body in a group'' why can't I find it??? ps: I have relese 19 .
Greetings luca:finger:
if you press the function with a double click it remains active, a bit like with office.
ctrl+y = to repeat the last command
Hey, guys.
I also take advantage of a question.. .
I read on a mesh tutorial of a command that though I can't find on my catia v5.
In practice, once designed by the sketcher, it would be enough for me to click and the web command to get parameters set previously in the sheet metal design.
but can't the web command wash it? ? ?
Can you help me? ? ?
Thank you very much
Good one!
Do you know falonef where I can find the map caia commands?
- - - updated - - - -Hi.
I would like to add the quick ctrl+\ button.
but does not take \
How can I do that?
esc (escape) - abort the current process or exit the current dialog box (when there is one)
f1 - catia v5 assistance (get contextual online help)
f3 - structure tree out or insert (toggle specification tree display on and off)
f9 - toggle hide/show
f10 - toggle swap visible space
shift - f1 - context assistance (get help on toolbar icons)
shift - f2 - toggle the specification tree overview on and off - opens an overview on specifications tree in a new window.
shift - f3 - structure tree activate around e.g. character size to modify (activate the graph if the model is active and inversely)
shift + left - rotate to the left
shift + right - rotate to the right
shift + up - rotate upward
shift + down - rotate downward
alt + f8 - macros start
alt + f11 - visual basic wordprocessor
home - display the top of the graph
end - display the bottom of the graph
ctrl + page up >> zoom in the model or tree whichever is active
ctrl + page down >> zoom out the model or tree whichever is active
ctrl + right arrow >> move the model to the right >> pan
ctrl + left arrow >> move the model to the left >> pan
ctrl + top arrow >> move the model to the top >> pan
ctrl + bottom arrow >> move the model to the bottom >> pan
ctrl + shift + right arrow >> rotate the model around z axis clockwise
ctrl + shift + left arrow >> rotate the model around z axis anti clockwise
ctrl + tab - switch between the different windows (swap active document windows)
ctrl + n - new document open
ctrl + o - document open
ctrl + s - document save
ctrl + p - document print
ctrl + f - search
ctrl + u - update
ctrl + x - cut out
ctrl + c - copying
ctrl + v - insert
ctrl + y - redo
ctrl + z - undo
ctrl + f11 >>>to get the prselection navigator, for selecting coincident / very close elements in geometry area. pls note: the preselection navigator cannot be used with selection filters.
page up - relocate the graph one page up
page down - relocate the graph one page down
up arrow - relocate the graph 1/10th (one tenth) of a page to the top
down arrow - relocate the graph 1/10th (one tenth) of a page to the bottom
left arrow - relocate the graph 1/10th (one tenth) of a page to the left
right arrow - relocate the graph 1/10th (one tenth) of a page to the right
alt + enter - properties
alt + shift + right arrow >> rotate the model
alt + shift + left arrow >> rotate the model
Hello, thank you all.
I would like to add the quick button ctrl +\but does not take \
How can I do that?
greeting everyone in the area. I am trying to configure some keyboard commands in v5 cat so as to simulate what I normally perform in other environments such as s.e. and inventor. in particular I need to move to the iso view with the ctrl+i keyboard combination, to the front view with ctrl+f, to the top view with ctrl+t and so on. I would also like to switch from one display mode to another (from wireframe to shading and reverse) by pressing a single key (in inventor I use j and k keys). Unfortunately, these commands are not mapping on the keyboard but can only be attributed an alias. I was wondering if there is a possibility to intervene on some registry key or other settling to unlock these and other commands that speed me a lot if activated by keyboard through shortcuts.
I don't hide that I would also like a keyboard command that zooms me from a mouse wheel without having to buy a mouse 5 keys or 3d. the current pan, zoom and rotate combinations are impractical from central and dx key, already better with central key and keyboard but zooming with the central key pressed, taped on the dx key and mouse back makes thinking about software designers with alcoholic problems. that you can do to improve the thing without accessories, i.e. staying at the minimum mouse+key? thanks early.
Have a good day.
I am Brazilian, and from what I understand you want to configure the keyboard to use only one letter as a shortcut. similar to the inventor.
to solve this, just use the catia version in p1.
va menu: tools-options-general
select the p1 option
reboot cat
configure commands using apebas a letter.
all questions can contact me: v5macros@gmail.com
visit the blog: http://catiav5macrosbygava.blogspot.com.br
found many useful macros.
Good morning to all, I ask about this old topic, but rather precious. . . lastly work with catia (always solidworks) more than other put on the table and some insertion parts in the 3d for now.. I would like to ask you how to access the keyboard commands. I hope someone can answer me that would help me, thank you stefano
