stevie
How did the matter end?
we bought it, the machine has a certificate of conformity.I only read the matter today.
If you do not protect it correctly I can assure you that it is definitely out of order. or outside you have suitable class (1) or you cannot use it. and if that radius is reflected somewhere and goes to interest third unprotected people? have you made the measures?
we are dealing with a very similar case and we have built a suitable carenature closed completely to avoid even reflections; Then, calculations to the hand, we evaluated the residual risk. A job.
Remember that in front of a judge training and dpi do not justify the design of suitable machine safety devices. if you could have installed them then big risks.
Let us have a little thought.
I've done it a lot.I remember that the marking is not always synonymous with safety. for Italian legislation (laws of Legislative Decree 81/08) if you purchase a clearly unconformed machine or equipment, although marked there, you are responsible in case of injury or inspection by supervisory bodies. There are many judgments that prove it. So you better protect those who use it.
Unfortunately, there are many of these examples and, unfortunately, Italian law blames more those who use it than those who produce it.
similar phrase already felt by some builders (the tiny is wanted) oriental.then I bought protective glasses suitable for that laser class for each operator.
from what I knew the machine can operate in that way after training of the operators and supply of adequate dpi.
I know that some manufacturers sell laser cutting machines without adequate protections by handing everything to the customer user that so you can "customize" the machine according to the needs, in practice buy a semi-finished and become you the manufacturer, and then if there are problems you accept responsibility. .Shouldn't it be our job to install the protections, should it?
all remarks widely already made weeks ago...I only read the matter today.
This thing is not standing...I know that some manufacturers sell laser cutting machines without adequate protections by handing everything to the customer user that so you can "customize" the machine according to the needs, in practice buy a semi-finished and become you the manufacturer, and then if there are problems you accept responsibility. .
In many countries they work with open cabins and the concept of safety at work is very vague.
That's why I suggest you avoid these builders, just like they sell you a car without belts, so then you can mount whatever you wantThis thing is not standing...
to understand it is as if a plumber signed the certificate of conformity of an electrical system. . .
send the seller also the complete technical dossier of risk assessmentlabels have been attached to the machine, the manual seems to be in the translation phase.
they will never send it to you...(and they are not required to do so)send the seller also the complete technical dossier of risk assessment
second en iso 12100:2010
I think so.they will never send it to you...(and they are not required to do so)
