raf
as from title.. .
I need to insert in my mileage drawings (even 12,000) of dynamic blocks, always the same but repeated precisely n times, I thought the use of the blocks lightened the design, creating instances and not copies of the starting block, instead apparently not so, the design comes to weigh easily several mb.
Given that I need dynamic blocks for at least 2 reasons, I would like to know if there is a way to make these last lighter (graphically they are already reduced to bone!).
Thank you!
use autocad 2009.
Thank you!
use autocad 2009.
