long curved pattern
Hi hunting,
I don't understand the purpose of the video, would you like to see the same with other cads?
Hi hunting,
http://www.cad3d.it/forum1/showthread.php?t=35324in another discussion it was said that high end cads reached the same ease of use of mid-range: I thought of studying some basic cases to verify the truth of this statement. I know that swx has no problem doing this, I was curious to see how other cads manage it like creo or nx.
Okay... now it's clearer, as soon as I find a little time, I'll put the movies about creo.
on the series of holes on curve, 3-0, ball at center. :smile:
Sorry to me look equal, I don't see the obvious differences you refer to (among other things I used an ancient version of if).
ale I have seen that you have incorporated movies in the messages, I do not remember how you do ... so avoid loading them on the external link.
I see in itself a sea of clicks and the selection of individual curves, am I wrong?
true, but only because it has set the curve selection on "single", you can select the whole curve with a single click by changing the selection setting on "chain".
Bye.
Bye.
and if you have 50 separate curves and want to concatenate them?
I explain better, you have 50 sections each section consists of we make 7 parts and you want to concatenate everything only at the end with 50 composite curves, how do you select chain for 50 times?
I don't understand what you mean; However we are talking about axieme pattern that leans on the feature pattern on una curve.
It is not possible to create a feature pattern on multiple separate curves, so there is not even the selection problem of multiple separate curves.
Bye.
Bye.
depends on what you have to do, my question is simple, the problem exists at least for what I do.
I'll explain better, you have 50 sections each section is made up of 7 parts and you want concatenate everything only at the end with 50 compound curves, how do you select chain for 50 times?
My question is simple.
It'll also be simple, but I don't understand either. Maybe because you talk about separate curves that must be chained up. If they are separated, for what is my knowledge of the concatenate verb, they cannot be concatenate.
I don't understand the bold phrase: "return to the end" what?
Perhaps with a short video could be clear to what practical case you refer to
but you know I'm a cadzo technician and as such I say only cadzate
:confused:
I don't know what else to do. Maybe every one that has clear to what operation you refer will have the goodness to explain it to me. otherwise amen.
