to fold a flat element you have to use the fold function from sketch.Good morning, if I had to get a semi-tube from a flat sheet, how should I do? I've been using solidworks 2021 for a few months and I haven't seen a case like this... I wonder why I did some work on the pavement that would probably be complicated to do on the "calandrate". I should have an internal radius of 981 mm and the outer radius of 984 mm being the thickness of 3 mmm.
I tried, but the processing is "coated" (and therefore not seen) once I return to the calandrate after adding a processing on the pavement. Maybe I should do it differently. . .to fold a flat element you have to use the fold function from sketch.
but you should shape the sheet metal, stretch it, do the work and then fold it.
you have to use the appropriate stretch and fold functionsI tried, but the processing is "coated" (and therefore not seen) once I return to the calandrate after adding a processing on the pavement. Maybe I should do it differently. . .
Thank you. Then I try. If there's something I don't understand, maybe I'll get resentful. I used so many years pro/e - I create but solidworks I still don't know him so much.you have to use the appropriate stretch and fold functions
@melnetto81 respond to requests from other users?Thank you. Then I try. If there's something I don't understand, maybe I'll get resentful. I used so many years pro/e - I create but solidworks I still don't know him so much.
