maximum encumbrance
  • Thread starter Thread starter stef_design
stef_design
is it possible to see the maximum encumbrance of a particular?
both visually and solid solid.
grazie
you can.......personalize the toolbar and add the command "create a rough"
this command should also be found in the machining module
I don't know... the command is active.
try customizing commands and see if you can enter the command I told you before
I checked, but it takes a special active license. I have the md2 and the command not present.
peccato:frown::frown:
I found the command in the workbench generative shape design....... Right-click on the command bar and activate the "surface machining tools" bar
by activating "only" the generated environment shape design I don't think you have that toolbar available. you need to activate another license...
Sorry, I joined two messages and now only appears in my username. I hope the user who had posted his answer doesn't want to. :
you at that point you have to go through the workbench that had already been proposed to you in the forum. I don't remember the name. precise that this function is not present in the gsd module.
