stef_design
is it possible to see the maximum encumbrance of a particular?
both visually and solid solid.
grazie
grazie
so can I do it without special modules?you can.......personalize the toolbar and add the command "create a rough"
this command should also be found in the machining module
I checked, but it takes a special active license. I have the md2 and the command not present.I don't know... the command is active.
try customizing commands and see if you can enter the command I told you before
voilà, only with the basic license. I don't know if that's what you're looking for.I do not find the option but esite and there is no need for a particular license.
but the solid in wireframe you see is only visual or is it a real solid?voilà, only with the basic license. I don't know if that's what you're looking for.
I wanted it solid.no visual only
