davideingSp
Hello, everyone.
I'm working on a university project with pro/e.
I would need your help because unfortunately in lesson we did not see how to use this section of the program and so now I am a bit in trouble.
I need to create a "gear" link between these 2 toothed wheels.
as you see the wheels are bound one on the engine tree (the green one) and the other on a tree that has to move.
My problem is that I can't "align the teeth so that these are tangent during rotation and at the same time make sure that the holes of the toothed wheels coincide with the axes of the respective holes for locking through thorns (for the red one) and locking through screw (for the yellow).
I would have managed to get a gross solution by moving the dentate wheels with the "manina" so that when I create the gear the teeth of the wheels are tangent to the sight but the problem is that when I go to analyze the global interference I report a superimposition albeit very small and I would like to solve this problem.
the toothed wheels have for
-red----- primitive diameter 35mm --35 teeth --- form=1
-yellow---- primitive diameter 16mm --16 teeth ---module =1
the pressure angle is 20°
I don't think there's any problem with the raid.
Can you tell me how to proceed? are really in crisis:frown:
as you see the wheels are bound one on the engine tree (the green one) and the other on a tree that has to move.My problem is that I can't "align the teeth so that these are tangent during rotation and at the same time make sure that the holes of the toothed wheels coincide with the axes of the respective holes for locking through thorns (for the red one) and locking through screw (for the yellow).
