because in solidworks you make an external surface and an interior of the skin thickness and if shell models you have to hold only one of them or the intermediary. Usually, if you produce an external mold, you mesha on the external surface so you can change the laminate (often) without having to change the mesh.by wave: I understand what I should do, but I can't do it on the program. what was the problem of importing in hm the geometry produced directly by solidworks? Why is it better to work on a third of the circle? and above all, how do I replicate everything I did on that third to get the full piece?
