model space with different scales
  • Thread starter Thread starter sandrix
sandrix
Hello everyone
I ask whether there is a way of doing so, which within the same
model space (standard design space ... not layout )
have two different stairs, and without using detail and self-detail
or I imagine using detail, but then disconnect it from the source,
but maintain the characters of the automatic quotas on the scale value... ? ?
apart
Of course you can do (e.g. by changing the var. dimlfac on the selected quotas), but can you clarify this part better?
I have the need to represent a scale "detail" for example 2:1 or 5:1
of a portion of drawing on three views "a-b-c" plant opposite side that actually at the end of the drawing
remains a-b plant front ... but the side "c" is elimated of these but remains the saying in a larger scale all quoted
with the correct odds taking into account the scale factor.. .
to obtain this dictation in a larger scale I use the comado detail, but at the time when I delete the view "c"
the detail disappears,
If I explode the odds lose the scale factor... .
here explained , and I repeat I can not use "space layout"
Coem drives this dimflac... ?
1) Sorry, I didn't see you using mechanical cad (I don't know it): That's why I didn't understand the detail command.
2) read well: dimlfac and non dimflac (see guide)
3) layout space: why give up one of the most efficient and proven potential of autocad, introduced already for almost 15 years? It's like owning a ferrari and traveling to the top in the fourth.
Are you talking about mechanical? or does autocad have a special command in the express tool?
if it's mechanical.. . personally I did some tests and even deleting the generating view does not erase the detail.
It is true that it loses the scale relationship, but it is not that you can work counternature and claim the same results.
just look for a carpiata solution with half screwdriver to the right and half to the left, you create a layer that you will freeze and you put all the view c. the detail remains referenced and you do not see and you do not print the view c.
and I agree with you!!
explain it to the ignorant of the ceed
of my company. ;-)
