dacorsa
I am here to ask you something of ansys, I did this model with solidworks and I imported it into ansys as a step file (which difference is in importing as solidworks files?), I defined the part that will be studied as ink and applied a linear deformation on the edges you see in photo, that is the entry of this flexible stainless steel. Now the problem is that I don't know how to tell ansys to also apply a rotation of the edges, a rotation of 8°, how do you do it? I found in "displacement remote" the possibility to insert a corner but then the model in the simulation deforms in an incredible and unrealistic way. How can I do that?
