modello in ansys workbench 14.5
  • Thread starter Thread starter dacorsa
But then how do you expect us to give you a hand if you don't explain your model?
useless to ask if then the hypotheses are not clear.
How can you simulate two independent bodies in a simulation? or bind them to each other otherwise it is obvious that they deform you of 7 km!
Then take a small glass put it in a big one and put both on the table.
if with a hammer from a blow on the outer one, the inner one breaks/drops? ? ? ?
See you.
ps: this to say: did you bind the two surfaces between them?
dear Valfe
cmq the internal one moves along with the external one, but here remains firm and the external one penetrates the inner one
I will keep you informed
no is well bound, let's say if I impose a great deformation does so
now works well, but how can I find force and moment applied? at a point or section? Can you help me with this?
Well, you can see the characteristics of stresses in constraints / couplings.
How do you say "now it works well"?
just to remind you, the spirit of the forum is to share. you ask, we try to help you but if you find the solution you should share it.
I have already answered, putting a smaller deformation doesn't make me this problem, that's all.
You know how to answer the previous question, how to find strength and moment at the extreme?
I answered you. if the extreme is bound or coupled yes, otherwise not.
now I have no ansys under hand but there is among the results also the possibility to evaluate the reactions
