Tristus
but the professor only wants the 2d? No 3d?? You don't understand well.... however I mention the delivery that the professor has provided... "drawing, with measures to please, the orthogonal projection, the section and the monometric asonometry of the figure "t" attached "
We draw everything strictly in 2d ... as if we were drawing on paper (the old way).
draws the 3 xyz axes. Let's help with the image I posted below. I press that I belong to the old school so I make great use of the keyboard). by keyboard type the command "snap" and press Enter. immediately after prizes r and then sending newment (r stà per rotate... in the snap command you will not see the r but rub it, which is so much there). the snap command with the r option will require you a point, you give the b point, then it will ask you a second point and you give the d (use the end point when you select these points). at this point the cursor will align with the b-d line. this will serve you to track the lines that start at the d-c axis parallel to the b-d axis.
finished tracking the lines (in the image are blue colored) back the snap command with the r option, selecting the c and d points this time draws everything from the b-d axis parallel to the d-c axis.
and so the plant is drawn.
now we return the cursor as it was before typing snap, r, and typing 0.0 (zero comma zero) sending and again 0 as angle. the cursor will return as it was initially.
now draws all vertical lines, reproducing the design. the vertices of the solid will be identified by the intersection of 3 lines. it will be enough to make the appropriate rotations of the snap (as outlined above) to pull all the lines we need to locate the solids.
They taught me how to do this. I don't think we're going different today.
Anyway, everything is needed to practice.. .
