multiplication in table
  • Thread starter Thread starter DANI-3D
DANI-3D
Good day to all,
I have a memory vacuum, age progresses, I do not remember what is the best system to get the product of two parameters inside a table, I explain better:
in the table of a set I have a table containing some columns with its parameters, two of which are quantity and length, I would need to insert in a new column the total lengths of each component, obtained from their multiplication.
Thank you in advance for your help.
It's true, but I don't remember the syntax, I basically have to create a new parameter that contains the value I'm interested in inserting in the table.
I'll get some evidence.
I stepped forward,
I found the right syntax for relationships, lungtot=rpt_qty * asm_mbr_lung
but I still couldn't recall the new parameter in the table.
Good morning to all,
I have been on the forum for a while but this is the first discussion I take part in.. .
I followed the instructions to create a similar table but I am not returned the lungtot value.
what can depend on?
n.b.:
I entered the formula lungtot=rpt_qty * asm_mbr_lung in the reports of the repetition region and it gives me no error.
thanks in advance
what can depend on?
n.b.:
thanks in advance
It should be so, I go to memory:
Let me know.
p.s. would be good and right, source of salvation ... to present itself in the special space.
ok now works perfectly...and excuse me if I didn't introduce myself. I've been following the forum for so long and I've never been involved in a discussion. ! !
good morning, I place the image of repeat table relative to a forming equipment (fonderia) in which I find incongruence with the total of a voice, in fact in the section q.ta, of the image 1, there is cylinder_anima=q.tà 1 that sumsuming 'sand resin' I get the same result of the image 2 with cylinder_anima=q.tà 2....where I mistake...thanks
