maxopus
azz .. sorry I didn't notice, I unfortunately have uninstalled the wf3, let's see if someone intervenes that has it.
You're in a good mood.you checked if in the final part of the wing (the tail collected to interderci) the union did not change the geometry of the wing itself?when I join the chord disappears and the tail becomes acuminata!!! I don't understand! !
the large surface that overlaps in the hole surface of the wing is the wall of the wind tunnel (it is the same thing as previous posts only that I modified the size of the tunnel).
the problem is that when I join (as you explained) disappear the chord in the tail!!!
Bye!
Loire
change and opens a drop-down menu on the right.How do I set precision? ? ?
Lorenzo
