open file step directly in ambiant sheet and more
MARCOC
good evening to all, it is possible to set the opening of step files so that the generated parts are directly in sheet environment??? using a specific template? ? ?
second thing where it is possible to set the value of the corners in degrees??? Why importing step1615575312131.pngthe measuring units of the corners is setatta in radianti
if it is not possible directly from the step.. Once you form the parts, convert the parts into sheet?? ? ?
I think there's no way. It would be nice but... How would the program understand the thickness?
Autodesk employees seem to be working to solve this... but without success.
to understand the thickness I don't think it's a problem, as inventor already recognizes it when touching a component's face, so I think it's enough to tell him to select any face of the step
