you need to search the forum from the panel. However in the discussions of students or mechanical designs you will find so many kinds of gearboxes done so because this year they were all fixed with that design.where can I find mechanicalmg?
like that:finger: then you have to see what you need
who:http://www.cad3d.it/forum1/showpost.php?p=279628&postcount=1only that instead of being a separate list, it is "disegnata". . .Guys. where can I find the distinct components of the conical wheel reducer? found in my first attachment.
I felt bad... I meant the names of the reducer components... (the separate component)... not the annex. . .
Why do I need them as I have to go in the drawing table... okay?
certainly is part of the exercise.I suppose it's part of the exercise/work you have to do. . .
That's not good.Okay now? I tried to try to make myself![]()
quoto, I would also add the quantities for each component present in separate: many times it helps!! !That's not good.
apart from that I do not like some line thicknesses, restraints, etc. in the table misses the column "material", missing the column of references (as it says fulvio "ruota dentata see dis...").
You write "cuscinetto" and then? What bearing, do you know how many there are?
the table must escape any doubt to those who must realize, assemble, the artifact. can't just be a list of parts.
not only, but ball bearing, rollers, otherwise it could also be a goose feather pad, no?! ?You write "cuscinetto" and then? What bearing, do you know how many there are?
where you find both the type of bearing, and the diameter, and the number of components. And that's not all.> n. 2 - roller bearing dxx
