cacciatorino
I would be comfortable to tie the distance between two parallel planes from a quota, variable according to the value of a certain equation or global variable.
The problem is that I can only do this by using auxiliary geometries on which to build these plans, for example design a sketch guided by the above variables and then use it to generate the bound plans. is it possible to avoid doing this tour?
p.s. why does every time I edit the value of a global variable give me away the comment I put on it?
