parametric barrel windows and variable section walls
  • Thread starter Thread starter DeDios
@dedios
if the arguments are not relevant to the title of the discussion, it is appropriate to open new ones, so that they are easily traceable and readable also by other users, as well as improve the use of the "search" function
Hello everyone!
I put myself away from time and hope to have an answer.
I am trying to insert architectural pillars, I define the procedure I used:
I open a new family / I choose generic metric model / I insert a reference from the cad for the base / extrusion-solid and "lucid" my irregular wall starting from a vertex that I remain made coincide with the point of origin of the family itself / closed the contour end the operation and in prospectus the rise of what I need / extrusion-e and design the openings in plant and raised /
Now the pillar merges with the system wall but I have several problems:
1- In the plant the stratigraphy is not perfect remains the trace of the outer layer of the system wall inside the architectural pillar, if I move the exterior finishes of the system wall inside the nucleus the finish extends irregularly towards the edge of the architectural pillar, in short I can not manage it. .
2- in the 3d the right side of the architectural pillar does not inherit the material of the built-in system wall, I tried to change also from objects styles but the pillar seems to remain in concrete even if I change the material, besides remain visible the joints between system wall and pillar. In short, the only material visible in 3d and rendering is that of the open side of the system wall. How to do that?
3- Once this holy irregular wall or with variable thickness in the plant, will it be possible to combine the normal walls of regular system that touch it? will it be possible to control the surface of the architectural pillar ("extrusion"-"painting"-"divid")? Will it be possible to connect ceilings turned on the side of the architectural pillar?
help me please!! !
I understand that you have a problem, but you cannot repeat the same question (more or less repetitive) in various discussions ....
what you found, it's the state of current art...
seeing answers on the theme stopped for more than 5 years and not receiving answer to my type of problem I wanted in this message only to highlight all the steps, I thought it could be useful to someone with my identical problem or maybe to be corrected by someone more experienced.
In the end I found only one reproach!
I didn't want to be repetitive, I'm asking for vein.
