tonygancio
Hello everyone,
I am trying to create a parametric set to be able in a short time to configure a machine that could be customized: it can be longer/ shorter, high/low and according to the measurements the axieme must behave in a certain way.
now, according to you what is the most convenient method to use by calculating that also go library parts (cuscinets, motors, straps etc.)?
I thought about the multibody but here I can't insert the library parts (at least I don't know the method to do it) or iassembly of ipart, or ilogic of the individual parts and then axiemarlo "by hand".
if you have other proposals are welcome!
Thank you so much to all!
No
No
