elbbb
Hello I have a problem in performing bends in loft.in practice I can bend but when I go to explain to the sheet the bending lines are not displayed.to make you understand better I will explain to you step by step my problem.
1 I must bend with this swallow profile"1" in "image3"
2 to make the loft I make a plane parallel to 50mm where I have to do the internal offset (of the rod) of es. 10mm, and here comes the first problem does not perform the offset but I must prolong the curves "1"
3naturally to execute the loft the profile must be continuous and without edges, so fitting the curves with a perimeter circle radius1, I clean the design by cutting the excess lines.
4 I make loft maa there are no traces of bending lines"5"
Maybe I'm wrong method but I don't know exactly what other roads you're taking. I'm doing the bending lines if I do the offset of the 2 curves without extending the lines and fitting the radius of 1 but the offset becomes too wide(image4).I don't know what to do I'd be immensely grateful if you give me a hand.thanks
