in one I selected in <stile di="" visualizzazione=""> "shaded with edges" </stile>in this other I selected "removal hidden lines" (the classic voice for the table harvests)is clear the error I hope
It makes you see that because it's all radiated. put visible tangent edges
I am not even saying that if there are no privacy problems the file should be attached especially if the problem arises specifically on that file.
not in isometricsThere's no problem at the side level. in the design environment instead the issometrica is seen badly even with tangent edges activated. I'll try to figure out what's wrong later.
I found the hippo... about.
the model is hurt, there are continuous surmounts of the plates and this creates troubles, which and why I do not know.
Solve the geometry of the model by trimping with appropriate size the areas that overlap and you will see that the model will appear
