Salcip
Hello everyone,
I'm trying to make a set but I have a serious problem with constraints and I can't figure out where I'm wrong. in particular I would have the need to insert a bearing inside a hole coaxially practiced to a pulley.
in the assembly environment I carry out the following operations:
1) Load the pulley (from me drawn);
2) Load the bearing (loaded from the skf site);
3) I impose the fastening bond on the pulley;
4) I impose the bond of coincidence between the symmetry axis of the pulley and that of the bearing;
5) I impose the contact bond between the outer surface of the bearing and the inner surface of the hole practised in the pulley.
The problem I'm facing is redundancy. I am aware that the two constraints are redundant and even ignoring this notice the assembly does not happen properly.
I would like to understand where I'm wrong and how to properly bind the two parts.
I attach screens to better understand the situation.
