marcof
It's a bit that I don't look for different tutorials or guides from online help.You said well, I've got a big mess in my head, but I'm going home now and tomorrow I give myself full time to this. where can I find material to erudite me?
if you do a nice graphic pattern, on paper, type feature manager, of a main set, which contains parts and subaxes that in turn contain parts and possibly other subaxes you can plan a simple series of tests on elementary parts (holes and nothing more) to understand how you can propagate external relations.
begin with an ax1 set that contains a part1, on this build a subassieme ass2. enter subassieme modification of ass2 and insert a part2 that models leaning to part1 geometry. then open ax2 and from there insert a part2b component that models on part2 etc. etc. so you will see when you can make changes and when not. For example by opening ax2 and entering part2 change will tell you that you can't, in the modificationsm leaning on the part 2b geometry...
In short, you have to make a nice chart where you understand how the main denn'assieme components are nested and then represent the transfer of allowed and prohibited relationships.
I don't dare reread because it will probably seem complicated to me too, but I assure you that the process is easier to do with paper and pencil than to describe.
You will also see that depending on the chain changes you want to make risks of creating circular references (back satan...) or in any case a chain of unnecessarily long references that could be abreviated by moving a component or leaning on a sketch of layout.
If you want to make topdown push modeling, you must have the logic of external references, of those who command what, when and why, you know it to menadite otherwise you create monsters so unmanageable that when you return from the weekend you will not even touch us again.
ideal would be to do a chord on topdown modeling, dedicated to your types of machines and made by a good one.
I have no idea how much time you're losing with these little cases, which still remain unresolved in the aid you're doing, even if you hand it to Mr. solidworks in person, but I think you've abundantly exceeded the cost of a good course of two or three days; If you have not passed it now, have faith: either come out alone and quickly, or that cost you will soon overcome it and will remain on the groppone the aid of an unmanageable bus.
