problem with buttons f8 (orto) and f9 (grill)
  • Thread starter Thread starter SimoneBaldini
SimoneBaldini
I have this problem, when I'm drawing a line (or other) and I press these two keys the program hibernates for a few seconds, from management activity I see that the program requires a lot of cpu, then it resumes to work. This does not happen if I press the corresponding icons or ctrl+l etc..
I tried to reinstall both autocad and keyboard but nothing, both with the wifi keyboard and the one on the surface does the same problem. for me it could be a conflict with some f8 function of windows but I don't know where to go looking. This happens to me today when yesterday windows10 did some heavy update I think.
Any ideas?
it seems to be (with f7 does not happen), but if I press f8/f9 when I do not draw it does not make 'no problem (low right it turns on or off the function regularly).
since a new update of windows 10 has been released and assuming that in many will have this kind of problem, to speed up the resolution of the problem you must set the variable timeverrides a
