Emergent
I attach two images from which you can better understand my problem.
insert the wound in the file with the sheet and place it on the face where it has to go.
while using inverted tool the wound is as if it developed within the thickness of the sheet and not outward.
I don't know how to make the wound go to "support" on the right face.
Could someone help me?
Thank you!
When I drag the wound on the model, no face lights up.
with solidworks there are no other ways to make the wounds, if not passing by the forming tool?
from what I understand, for each wounder (who will have its particular quotas) I must have a part saved between the forming tools or a part with different configurations.
Right?
in solid edge there is a dedicated function and it seems much more intuitive and quick.
Thank you!
Right?
