problem with scale
  • Thread starter Thread starter kamikaze
kamikaze
I'll give you my problem.
I have to enter a scale that covers me 5 floors, the problem is that I can't get it to the end. in the settings both that as the final constraint puts the 2nd or 5th floor does not change anything always to the 1st. if instead I go to insert as final bond on the 1st floor and as next the 2° then I can cover also the latter, but still there are no other successive levels to indicate and then I remain screwed...:confused:
a single scale covering 5 floors?? if the planes have the same distance from each other you can try with the parameter "top level"
I'm really idiot... I was referring to that command, but naively I didn't try to set the top floor, but I wanted to do it in succession, that is to indicate every plan. thank you very much indeed, you are always available and very efficient!!! :
