problems with file/folders solidworks 2020
  • Thread starter Thread starter scagno71
scagno71
Good morning to all, I presented myself in the appropriate section, I am a mechanical designer and for a few months I have passed from inventor to solidworks.
My problem is the following: I started with 2019, now I was upgraded to 2020.
with 2019 I had no problem, now with 2020, I create my files (both parts and assembling), and save them in the archive folders of my drawings. When I go to try to reopen them, in the folder where I saved them, as soon as I see the whole list of files, the program crashes. the same thing if I go to see the files in the folders with explore resources, after a few seconds when I see the list of files, it also explores resources crashes.
It seems almost, but I speak as a profane, who struggles to load the icons of the parts and/or assemblies, and fails to view them and crashes.
This only happens to me with files saved with 2020.
what could depend on? It's a big problem, 'cause I can't work anymore by not opening the files created. . .
thanks for any answers!
hardware
check if you have assistance. in this case contact them.
try to remove the display of thumbnails in options>general system options
when the program closes strongly always sends the report
Thanks massive, I tried, but the problem also persists in this way.
I sent the report, in the meantime I will try to contact the assistance (the problem is that I work on a license of our partner in Belgium, and the assistance they have). We'll find a solution.
for now thank you and hi, I will keep you updated (also because I will have other issues to submit on the program). .
hardware
check compatibility of video card drivers.
if you can reinstall the program, maybe it is a trivial installation problem
other questions to circumscribe the problem:
do files reside on the local pc?
you are using a sharing system (not necessarily for these files) type dropbox?
has the problem just installed 2020?
are there additional applications (routing, simulation, compose...)?
opening files without displaying them, for example through the recent list, is it?
opening a file done in 2019 will not crash, but if you then save it in 2020 will crash?
launching the file to explore resources, so with closed solidworks, what happens?
1 - files are saved on corporate network
2 - no dropbox
3 - in the package is included visualize and composer. I tried to open one of the "encrypted" files with visualize and gives the same problem
4 - from the recent list I can open them.
5 - Yes, 2019 files open them, then if I save them with 2020, when I close them and then try to reopen them crashes
6 - it becomes difficult to manage even to launch them from explore resources with closed sw, because it really leaves me a few seconds before crashing there too. Anyway, I managed to open one, and it opens.
I can't understand what's happening to him. .
1 try to open them from local
3 deactivate all additional packages
4 I would exclude both an installation problem
6 what it means
It really leaves me a few seconds before crashing
? a closed solidworks double-click the file and opens you, hoping the extension is properly associated, the file in solidworks. or right-click and select with...
