graziano-g
hi, I need to apply fittings and drilling on fixing plates of different sizes in a repetitive way.
I then generated the library file that you find attached.
to be used will be downloaded, extracted then added to the folder below the path or, after generating a custom folder in the project library, will be inserted into it to keep it separated from the libraries installed with sw.
but you already know that.
c:\programdata\solidworks\solidworks 2015\design library\features\metrico\serie di fori
function works, even if I think there is an initial anomaly (at the insertion of the function to me appears the preview of 5 holes in place of the 4 that will then be practiced on the piece ) and a final error message appears that however if ignored not by problems ( I do not understand where the hippo is.... ).
the preview of the result appears only after selecting any of the values shown in the column value under identifying odds even without changing the value.
I would then change the description that appears in the column name under identifying qualities from thur hole to hole depth and from thur hole diam to hole diameter, I tried but sw makes me a mistake that I can't eliminate, probably the solution is too simple... .
Does anyone want to examine the file?
n.b.
opening it is noticeable that the insert bar excludes the racking function.
if you move the bar at the end, when applying the function to a piece, you lose in the monitor the ignition of the entities that drive to the exact sequence of the selection. So I prefer to leave her where she is.
Hello, thank you.
n.b.
Hello, thank you.
