picc
Hello everyone! I am a mechanical engineering student and we were given the task of designing a parallel axle reducer to two speed jumps. the data that I have been given are:
number of incoming turns: 900 rpm
Rated transmission ratio: 16
input power: 1700 w
fe: 315 n( the engine that feeds the reducer is connected via a pulley system, but for simplicity we were told that on the input shaft acts this force with a certain angle).
the pattern of the reducer is the one indicated in the annex. in tree 1 enters the pair, from tree 3 comes out.
First of all, the professor suggested that we focus on dimensionaling (at first attempt) the wheels with helical teeth. we assumed that the nominal transmission ratio was divided as:
i1-2=5
i3-4=3.2
from the relationship of lewis, inserting the torque c1 on the pinion, the coefficient of lewis y (referred from the number of virtual teeth equal to 17) 3.31, supposed angle of the propeller equal to 20 degrees, dic equal to 17, z1 equal to 15 (minimum number without interference, and admissible sigma equal to 286,66 mpa (having chosen a cemented 16mncr5 steel with a tooth foot resistance of 860 mpa); we got a module value of 1.15.
from this value we have therefore selected a value of the recommended table module of 1,25, and from the reverse formula of lewis we have again determined the number of teeth z1. we did the same procedure for the pinion 3. Note the numbers of teeth z1 and z3 we evaluated from the transmission ratio the number of teeth of the wheels conducted z2 and z4. Finally knowing the 2 modules of the two pairs of toothed wheels, we evaluated the primitive diameters to verify the dimensions that we must respect.
I would like to have some advice on the procedure adopted and on the choices as dic and the material, if they are correct. I also think that the chosen data is not good because as a result I got:
logically impossible to not have interference!
thank you so much for the attention and apologize for the length!
input power: 1700 w
i1-2=5
i3-4=3.2
