picc
Hello mechanics! Sorry about my absence, but I was busy with the other project. Anyway I wanted to thank you for the material you posted!
I went ahead in the design of the toothed wheels and in their verification, and passed to the sizing of the intermediate shaft (the one on which the wheel 2 and the pinion 3) are calettate. I'll attach the excel spreadsheet to show you what I did.
Now I have problems choosing bearings: we were asked to choose the bearings so that they had a useful life of 25,000 hours, and knowing that the number of laps on the intermediate shaft is 180 rpm, it turns into a duration of 270 million turns. the choice is relapsed on a conical roller bearing model 30203 j2 from the skf catalog. now here begin the doubts:
1) is mandatory to choose two x or o-mounted conical roller bearings, or is it possible to mount for example a conical roller bearing on one side and a radial ball bearing that must only support a radial load?
2) in the calculation of the useful life of the bearing the askf fact depends on the ratio of viscosity k, and the value of the optimal viscosity is derived from a table according to the number of turns of the shaft and the average diameter of the bearing. as the reducer works at a temperature other than 40 c° (temperature to which the values of the viscosity of the various oils in the diagram mentioned above), to obtain the optimal viscosity at 70 c° the other diagram that binds the operating temperature with the viscosity of the various iso oils. Now what I do not understand is what is the value of optimal viscosity, and what value I have to choose viscosity for the oil that will be used.
3) with regard to bearing mounting, usually how much space is needed to be available for the installation of bearing locking systems (such as wreaths), how much space should be left between toothed wheels and bearings and how much between the two toothed wheels?
Moreover, in order to proceed to the fatigue test of the tree in question I also need the dimensions of the shoulders and their connection rays, how can I decide these values?
Sorry the length of the post and thank you so much!
