ygna
an information but can you perform pushover analysis with aansys? Can you tell me about some tutorials?
Thank you very much
Thank you very much
I think it is simply the application of a load that increases incrementally and the calculation of a coefficient that describes the behavior of the system (in practice stiffness?). if the problem is this is solved easilyMaybe you should explain what the "push over" is. .
