quotas visible only to a certain scale
  • Thread starter Thread starter Piron88
Piron88
Hello, everyone.
I wondered if it is possible in autocad to make sure that certain objects can be visible only in a certain scale of the layout window. I explain better: in an architectural drawing board I have quotas on a single layer called "quote". some of these odds I want you to see only in the 1:200 scale layout window, while other odds I want you to see in the 1:100 scale layout window.
same also for some block references.
Is it possible for you to do it with autocad??
if you use various fines for each window you can exclude its layers.
if in window 1 I have 1:100 scale drawing I hold the quota layer active.
if in window 2 I have the 1:200 scale drawing I turn off the layer quotas.
But turn off the whole layer, if you want a partial thing, you should create more layers.
if the blocks are on different layers (not content, but block by itself) you can do the same thing.
