Pamak
Good morning.
I press that I searched on the forum but found nothing (maybe I used incorrect search filters :frown
Sometimes I have a problem in quotation, I would like to insert a quota (fresh + line + text of the quota) that however must be interrupted regarding the theoretical point from which to take the measure.
Now as I now use the trick to insert a note but it is not functional as if I change the part to the table does not update (rightly).
I attach an image to make you understand better, the quota I insert manually as text is the diameter 104.3
thanks for the help:finger:
