quotatura
  • Thread starter Thread starter madmax78
Well, it would be enough to know how to make the threads appear, and then each one handles it as you don't think?
face sapeee
You're right, but we're trying to make a journal, and we're going to try it out and move it through. as soon as ready I will put it available for everyone. or also modified files to get gas holes.
I just wanted to let you know that ugs told me that the fact that I can not automatically quote a threaded hole, and that this recognized enga is not a problem, but only an improvement that will now be considered. but for us it is a problem.
the fact that it is not reconsidered is a problem, but in siemens prefer to improve the graphic interface.:frown:
Another problem is that a worldwide cad does not have gas threads, but in siemens have "other" priority.
face sapeee
I'm following two roads. the first is to edit the quota, combining a relationship. this opens a window and select the thread. this allows me to associate the quota to a feature. The problem is, however, I have to choose and I might even be wrong. . .
the second road is: given an external or internal file (type part families, it is to see if it recognizes them) to associate to a diameter a thread example : in diam.13.157 - output 1/4" gas.
all this should be done either with macro or journal and then associated with a button. I can't find the file running the feature parameter command to see if I can copy it and edit it.
still remains a Moroccan passage
Thank you very much for the excellent idea of the macro that creates a cylindrical thread with "m" prefix!
I would very much like a similar tool for gas threads, but the greater diameter or that of the drawn thread does not correspond exactly to the size in mm... a gas hole 1" is not drawn 25.4! I can't find any solution!
the only idea "porcata" that comes to mind is to remake a table such that threading a hole is drawn the gas fillet in mm to the nominal diameter, then quotating in in inches you would get the desired quota... but so doing physically the hole would be very different from the real one!
ps. but is it possible to delete the text from a quota? I just can't, but at a course I seem to remember that it is possible, so does not go to vary the feature.
delete no (at least up to nx4) you have to put at least one character, but space bar is a :wink character:
