quotature problem
  • Thread starter Thread starter Paco87
Paco87
I have made a 3d model of rectangular shape and small thickness, a sheet, there is a straight axle. in the table when I put the quotas it makes me insert them all without problems except that of the radius/diameter of the asola, in practice when I select the command of quota it makes me see the quota, but when I click to confirm it does not remain on the drawing.
I hope I've been clear.
you have to go into general options> ownership of the document>lines/ and select images with the axes of the sunshades in the center.
the second click (to place the quota), do it out of the piece you are measuring.
can be that the piece does not have a "normal" view and therefore creates that problem.
If anything you do a/two view projection and make sure it is not slightly rotated.
