meccanicamg
Since jeffcott puts two shoulders to hook the rollers to the frame I would say that they are just these shoulders to do as axial clamp for the bearing. I would like to recall x the umpteenth time that it is costing a heritage this tape....so it is good to minimize the processing, so no extra seeger on the free side.but are you sure of free bearing tolerances? usually to avoid lamination of the seats, the uncertain or forced coupling should be done on the ring with the rotating load, then anyway, a "something" that ensures that the bearing does not go out should be put.
the right bearing is what you have to move both if you stretch the shaft and if you stretch the roller.
This tape from a carpentry work is becoming a set of precision mechanics and in a while we will say that it must be rectified all and lap with tolerances of 1 micron.
for aesthetic factor even with the bearings outside you could have the same visual impact.
