cacciatorino
But so the roller isn't guided if you don't put a seeger on the inside one side, which will certainly cause the two seegers to interfere with each other if you don't put a spacer.on the engine roller I forgot to change the pulley that will have an internal diameter equal to 16 mm so as to avoid striving on the axis.
for both reels I have instead hypothesized axial slide of 1 mm so in case of expansion there is 1 mm between the right and the segger for both reels.
