cacciatorino
on the catalog skf.I say better, after you chose the bearing for example skf 61901-2rs1 where you see that tolerance you have to give?
..maybe the voice tolerances..?south catalogo skf.
I have one of '89 and I am on page 71..:biggrin:if you have the catalogue 'the desired bearings' printed in 2008, just go on page 158
Here we go. but my question I'm asking myself, as almost everyone is: why complicate life by putting the bearings in the tree instead of traditional? Actually, you don't earn anything like machine tooling or bulking. and there is a low structural rigidity because the bearings are small. But the charm of the different... not to copy applications from competition etc. ... good jeff. I also do so.I attach a photo of a weigher already made but I remind you that the substantial variation (for now only study object) is in bearings, within the rollers.
If you put the pulley on the crazy roller, it becomes the motor roller with pulley conducted.mechanical excuse tell me what to do in calculations if you put the pulley on one side of the crazy roller? I saw the file you put on the forum but I don't know how to do if there's the load of the pulley, maybe if you put the difference with the one before I understand more
..indeed, lost and raised costs. .Actually, you don't earn anything like machine tools. .
Yeah, sure. we put a pulley so much so that you make "two laps" on the roller on Saturday afternoon.:biggrin:but can you also put the bearing inside the pulley?
and the charm of the "different" keep it for you..:tongue::biggrin:...the charm of the different...
If we put the bearing in the pulley? calculating friction between spheres and slopes, at what speed should the pulley itself go to imprint on the shaft the torque stability?Yeah, sure. we put a pulley so much so that you make "two laps" on the roller on Saturday afternoon.:biggrin:
atofras, the pulley has to drag the roller in rotation. we said that it will be calettata, so fixed, on it; what does a bearing stick there?
And forgive the jokes. .
Marco:smile:
p.s. Of course you're joking. What is the world? :biggrin:
schema scheme:bekle:I got used to the jokes: cmq I said a bearing on one side of the roller and the second (on the opposite side) inside the pulley
and then smile::smile: what is that angry face?I got used to the jokes:
I imagine he thought he would fix it "in the head" to the roller, as extension of the roller itself.. doing "unique body" the cux "may" also be put in that area.schema scheme:bekle:
