maverick_87it
Hello everyone, I've been following you for a while, I'm also struggling with the design of a reducer, I just need the 1 tree and I have to do it by next week, so I want to show you a little this together that I came to see if the design as it is done can go.
on the shaft is calettata via tongue a toothed wheel with straight teeth, I am not sure on the positioning of the quarry and I perplexed (even after seeing 3 manuals) on how the wheel should be drawn, including the coupling with the second wheel.
Are the bearings well bound?
in the upper part I was told to insert a pin... really serve? If yes, I will certainly have to increase the thickness of the flange.
View attachment riduttore mio.pdf
