beppino
as from title, the refile operation, is important to every release change.
Is it also to do when you change maintenance release?
Thank you!
Thank you!
depends on what has been implemented and which fixes have been made on the mr.as from title, the refile operation, is important to every release change.
Thank you!
Thank you for the clear answer.depends on what has been implemented and which fixes have been made on the mr.
so there is no absolute answer.
I bring back my opinion / experience.
I work under tc.
transition from pre-nx7.5 releases, the refile is almost mandatory, otherwise it does not use the lightweight integrated with automatic switch.
if steps from nx7.5 to nx8 is recommended, but not necessary.
if steps from nx8 to nx8.5 is not necessary.
inside nx8, because only here there are 3 mr, I recommend it only for those who are under tc to pass to nx8.o.3.4 r, because there is an important fix in nx manager, that is that tool that interface nx with teamcenter.
I find it useless and a waste of time.Thank you for the clear answer.
I don't work under tc.
my doubt was also: can it be a correct speech to make a refile_part -d -s of every active project, at every mr?
this a priori, before evaluating whether it is necessary or not?
:finger: grazie.I find it useless and a waste of time.
maybe a bit off-topic but what fix do you refer to?... within nx8, because only here there are 3 mr, I recommend it only for those who are under tc to pass to nx8.o.3.4 r, because there is an important fix in nx manager, that is that tool that interface nx with teamcenter.
as well you know, with nx8 attributes can also be different from string.maybe a bit off-topic but what fix do you refer to?
Good day to all!
