reimpostare ucs globale
  • Thread starter Thread starter strato72
strato72
Hello.
What is the command that allows me to return to the ucs in the figure? Sometimes it happens that you change and I can't go back to the origin.
thank you so much for your availability, but sometimes maybe from keyboard it passes to the "buddy" uct to understand us better.
in two we understood two completely different things, maybe so clear you were not...
is right, in fact I apologized and above all I put it in quotes because I cannot attach the image
I put it in quotes because I can't attach the image
Why? if it is because you do not have it underhand just write -ucs autocad icon- or similar terms in google images and arm yourself with patience. or write to us that you will publish it as soon as you appear
the "cicciotta" icon is nothing but the image that the icon assumes depending on the view set.
in the display "wireframe" the icon appears as the one in the photo you posted on top.
if you choose a "realistic" view then the icon takes thickness and color.
benignly, if you draw in 2d it does not make sense to set a realistic or conceptual view. you choose the wireframe view.
with realistic or conceptual view draws in 3d, and at that point the icon is more visible and colored
You can try and give some command. first set the wireframe view from above.
then the command ucs choosing "global"
finally type ucsicon and set the value 1
the value 1 activates the icon (because you can also turn it off) and the force to remain displayed only in the lower left corner of the window or current layout, as in the photo you posted.
You probably set a view that is not wireframe.
