genesis1975
hi, I'm mounting the same spring on several assemblies and to make it stretchable in the first together I opened the spring sketch and I gave it coincident between the point at the end of the spring and the axis where it needs to be hooked and works.
Now the problem is that when I go to mount the same spring on another set, it gives me the question mark on the sketch, that is, the sketch already has a relationship of coincidence with the other together, and it does not take me the coincidence in the new together... How do I do that?
