Giovannino60
1) how to remove the external square in the layout space https://s32.postimg.org/l3btdntr9/per_togliere_contorni_esterni.jpg
2) I don't understand how to scale in layout, I did the rectangle in layout, I see the image, then I clicked on the rectangle, and I tried to put in scale already predisposed in stairs windows, example 2-1 that should shrivel the image inside the rectangle instead it gets bigger.
2) I don't understand how to scale in layout, I did the rectangle in layout, I see the image, then I clicked on the rectangle, and I tried to put in scale already predisposed in stairs windows, example 2-1 that should shrivel the image inside the rectangle instead it gets bigger.Thank you.
