repeat along curve
  • Thread starter Thread starter andrea1974
andrea1974
I have sought and seen other discussions on the topic but I just can't do this series on a curve.
Is there something wrong?
probably the living edge, connects with suitable radius
Alternatively you could try with chain
So the ray I tried to do it, but he doesn't see it. stops at the segment like it wasn't a polyline, or closed line. She sees her... You see that only the straight stretch is illuminated? What do you mean by chain? ?
attention that we are in the environment part not together. . .
However to the eye if you want it to be repeated along the whole path you have to create a composite curve formed by the various segments, if you read only a segment
Yes, I had seen this video this morning but I couldn't do it in his way by selecting the sketch of the bag as he does... I can't have tried many times in various ways but with the spline comes immediately. .
converting into spline each sketch for curve repetition cannot be the correct solution because a soline is a tangent continuous curve and by its nature difficult to manage. If instead of your sketch you have to manage a trivial closed chain or even the sketch of the video you're sure that you cry and unmadonna after 10 minutes.
the solution is to select the sketch from the function tree and not from the graphic area
Yes, but the speech is that you don't recognize the sketch of open segments as a curved line to follow for the series...
[edit]can be that the open sketch does not select it from the function tree, but the spline is not the solution[edit] we will talk about it when you have to repeat on a path without compromises like the links of a chain or belt
for the links of a chain it is better to use the special function.
you ok chain path you can not use some spline....it's already happened I had to extrude a fixed curve without following a path I wasn't able precisely. .
the chain handles with a special function and you can select the separate sketch elements (archies and lines) using selection manager
I can't open the file because I have 2019, but it seems to me that the problem is solved as I said more on, using the “composite curve” function with the sketch segments, so there is no need to turn the sketch into a spline
with composite curve the repetition arrives at the end of the first chord.
