stefanobruno
I don't understand. I'm still having trouble.I opened your steps with rhino 5 and many transitions on the fillets present problems
I attach the rows of rhino5, obtained from the stp converted by inventor and not further treated.
I'm sorry. I'll explain.I don't understand. I'm still having trouble.
I confirm, he says that to me too.the other piece "motor support" is recognized as valid but not closed polysurface (it is not a solid).
I would not be so optimistictherefore with the modification made by marius should be readable on any type of program?
That's right. .@marius the files you have corrected I guess are those edited by stefano?
Unfortunately or fortunately autodesk does not have the monopoly of the sw cad, no one would discover the faults of autocad in working in 3dI confirm, he says that to me too.
in the analysis of open edges, rhino5 does not report any.
the rhino file "motor support ", in inventor is opened as surface, sign of the presence of open edges.
the open edges however find them in the thread, made with a helid that, probably, in the various conversions has deteriorated.
the fittings that pro/e sees as corrupt, inventor digested them as fresh water.
the checkup that makes me create is more beautiful:I'm sorry. I'll explain.
importing your steps into rhino there are no problems, except that only "holy support" is recognized as a valid closed polysurface (so a solid ).
When importing your steps in pro/e 2001 problems occur on both pieces and in the same points, see the image highlighting the edges (yellow) with shredding errors that cause the unclosing of the surface union.
I think it has to do with the absolute tolerance set in the cad with which the pieces were originally made.
Good mariuss:finger:in the sense that in the files prior to those of mariuss creo and catia they detected so many mistakes to correct, after in the files of mariuss these errors are gone, then anyway I do not tifo for no sw@roar how?
